NDI
Scan Converter & Nvidia DSR
Hi!
Been runing vMix HD for some time and it's top notch compared to other streaming software. I'm a gaming streamer and are using NDI Tools to send my Gaming PC to my Streaming PC. Recently I discovered Nvidia DSR function (Dynamic Super Resolution) and are using it in a couple of my games. The problem I have encountered is that the Scan converter are not working well with DSR, the source are being cropped into 1920x1080 but with the DSR resolution. Is there a workaround to make the Scan converter capture the downscaled ingame resolution as my display screen are 1920x1080?
kind regards
Scan Convertor is a Newtek product. You should direct your inquiry at them.
NDI
