Kaf
#1 Posted : Wednesday, October 9, 2019 10:41:31 PM(UTC)
Kaf
I recently discover a new issue when using GT title inside an input multiview.
When I start a transition to my input with the GT title inside, the GT title seems to be restarting one frame after the "cut", it's weird because it's not happen every time.
I already use GT and multiview with no problem maybe it's a new issue introduce by the last update ?
Here is an example of the issue :
As you can see in the video sometimes the Title is already "complete" when I cut to my input and after one frame it's restarting.
I specify that it does not happen every time, you can see the few try in the video I uploaded.
Thanks for your time.
kmedia
#2 Posted : Tuesday, October 15, 2019 12:38:06 PM(UTC)
kmedia
I've been having this same issue too. When a GT title is part of a multiview, it sometimes restarts quickly after the transition has already started. Has anyone found the cause?
#3 Posted : Tuesday, October 15, 2019 4:35:14 PM(UTC)
Guess it is sort of a normal behavior not ? you have your regular transition which is also a type of animation and the animation of the title starting at the same time (= not a clean start)
Aren't titles not intended to be used with overlaying them and triggered as such for correct behavior ?
