GT
GT Title inside Input multiview not restarting correctly
Hello, I recently discover a new issue when using GT title inside an input multiview. When I start a transition to my input with the GT title inside, the GT title seems to be restarting one frame after the "cut", it's weird because it's not happen every time. I already use GT and multiview with no problem maybe it's a new issue introduce by the last update ? Here is an example of the issue : As you can see in the video sometimes the Title is already "complete" when I cut to my input and after one frame it's restarting. I specify that it does not happen every time, you can see the few try in the video I uploaded. Thanks for your time.
Joined: 6/18/2019(UTC) Posts: 27   Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
I've been having this same issue too. When a GT title is part of a multiview, it sometimes restarts quickly after the transition has already started. Has anyone found the cause?
Guess it is sort of a normal behavior not ? you have your regular transition which is also a type of animation and the animation of the title starting at the same time (= not a clean start) Aren't titles not intended to be used with overlaying them and triggered as such for correct behavior ?
GT
