Feature Requests
Shortcut - DataSourceSortByColumn
Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Hi, It would make my stats leader creation for athletic broadcasts SO much easier if there was a shortcut to sort the datasource by column! I am using a PHP script as a workaround, but I have to have 6 different datasources in vix to pull the same exact data, just sorted differently. The capability to sort is already built in. Surely it wouldn't be that difficult to add a shortcut to it.  Thanks Carey Edit: I guess its worth mentioning.... I need Descending sort order for my application, but I guess it could be selected in the shortcut. ie. Value = Name,Table,Column,Order
Feature Requests
