comporder1
#1 Posted : Wednesday, September 4, 2019 11:46:32 AM(UTC)
comporder1
It would make my stats leader creation for athletic broadcasts SO much easier if there was a shortcut to sort the datasource by column! I am using a PHP script as a workaround, but I have to have 6 different datasources in vix to pull the same exact data, just sorted differently. The capability to sort is already built in. Surely it wouldn't be that difficult to add a shortcut to it.
pic of datasource table
Carey
Edit:
I guess its worth mentioning.... I need Descending sort order for my application, but I guess it could be selected in the shortcut. ie. Value = Name,Table,Column,Order
