Joined: 8/16/2019(UTC) Posts: 355  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
 vMix Capture 23 August 2019 15-25-33.png (3,473kb) downloaded 9 time(s).Loving the software and the tutorials including the support from fellow users is great. One thing that I feel would improve an already great software would be the ability to crop(or mask) an area that you don't want shown. For example, I'm using a collapsible green screen and I can't hide the rounded corners when I use the X & Y, if you could use something like a pen tool to draw the area you wanted cropped (including inverted), this would allow only areas you've chosen to be shown. I do hope that makes sense. Keep up the great work. Attached is an image to show an example of the problem.
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
You can use Luma key for that.
Joined: 5/13/2014(UTC) Posts: 521   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
I'm not sure if the Luma Key will allow the same sort of control as you could can get by hand-drawing a Garbage Matte...
