Simsyuk
#1 Posted : Friday, August 23, 2019 12:25:16 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
vMix Capture 23 August 2019 15-25-33.png (3,473kb) downloaded 9 time(s).Loving the software and the tutorials including the support from fellow users is great.
One thing that I feel would improve an already great software would be the ability to crop(or mask) an area that you don't want shown.
For example, I'm using a collapsible green screen and I can't hide the rounded corners when I use the X & Y, if you could use something like a pen tool to draw the area you wanted cropped (including inverted), this would allow only areas you've chosen to be shown.
I do hope that makes sense. Keep up the great work.
Attached is an image to show an example of the problem.
richardgatarski
#2 Posted : Friday, August 23, 2019 4:19:45 PM(UTC)
richardgatarski
You can use Luma key for that.
zenvideo
#3 Posted : Friday, August 23, 2019 11:00:12 PM(UTC)
zenvideo
I'm not sure if the Luma Key will allow the same sort of control as you could can get by hand-drawing a Garbage Matte...
