imagebotique
#1 Posted : Friday, August 23, 2019 12:27:32 AM(UTC)
imagebotique
I have been using Blackmagic Design micro converters to go from a laptop (duplicate display to pick up powerpoint) then going into the blackmagic micro converter ultimately over SDI into a Blackmagic Decklink Quad 2. This setup was working fine for 4 days then come back into the studio on the fifth day and I get a split image.
I tried changing all kinds of input settings, switched to a different Blackmagic card (Decklink Recorder SDI input) and was still getting this split image. As a last result I ran a 50' HDMI cable from the same laptop to the same Decklink Recorder card and had a perfect image.
This being said, my setup worked fine over SDI for 4 days then on the fifth day it seemed that the only way to get this laptop captured was over HDMI. I know there are other options such as Desktop Capture, NDI to pick up this laptop input (my client wants it done a certain way so I am not looking for different methods of capture but simply how to diagnose how this fragmented image occurred.
To detail what is in the image, part of the image is on the top left of the screen and another part of the image is on the upper right part of the screen in Vmix
laptop capture problem.png (323kb) downloaded 7 time(s).
#2 Posted : Friday, August 23, 2019 12:39:37 PM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
imagebotique on 8/24/2019(UTC)
