donvago
#1 Posted : Wednesday, March 19, 2014 3:58:37 PM(UTC)
donvago
Good afternoon, is to buy a easycap capture, turns out I do not work all that well in Vmix.
I only capture audio without video. I read a bit and I found that there seems incompatible with that come with chip SMI Grabber Device.
there any way to solve this error? . appreciate the help they can lend.
excuse my bad English.
sontoloyo
#2 Posted : Saturday, March 22, 2014 9:58:09 AM(UTC)
sontoloyo
Malaysia
Do you have installed the drivers correctly?
I have Easycap. and it works well in vMix.
ask
#3 Posted : Saturday, March 22, 2014 6:59:50 PM(UTC)
ask
This is often because the drivers are not written for the later o/s versions. If you bought your grabber online (cheaply) you will need to do a net search for drivers that will work with win7 32/64bit. They may not have come with your device.
sontoloyo
#4 Posted : Sunday, March 23, 2014 6:30:23 AM(UTC)
sontoloyo
Malaysia
Driver easycap chip SMI Grabber
download
MrFreeze
#5 Posted : Monday, March 24, 2014 10:34:02 PM(UTC)
MrFreeze
I actually had an issue with these.
There are two causes from what I notice in my debug process.
One is that most motherboards can only run one smi grabber at a time. I'm guessing it has something to do with the usb having limited read /write speed across all ports
Two is using usb 3 instead of usb 2 well cause issues. Big issues. From no input to speed frames.
Freeze
