Webcam set up - Akaso EK7000
Hi all
i purchased an Akaso Ek7000 action camera from Amazon and it works well as a webcam (tested using numerous applications) however i cannot get it to work with vMix as a camera input. It shows the name of the device as "iCatchtek SPCA6350" but when i click ok to add the input i get an error saying:
AddNewInput.INPUT_CAPTURE The filter graph is circular.
not sure whats going on. any help?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
How are you connecting the camera to your computer?
It is connected via USB  Vmix.png (126kb) downloaded 4 time(s).
I'm having the same issue, is there a way to fix this?
