NiBTour
#1 Posted : Saturday, July 13, 2019 4:02:23 AM(UTC)
NiBTour
Setup:
vMix 22.0.60 4K
NVIDIA 1080ti
X299 i7 7820X 3.60
64GB Ram
SSD (4x Samsung 970s)
Capture cards:
BMD Decklink Duo 2 (latest firmware 11.2)
BMD Decklink 4K
Source:
Game RGB 4:4:4 16bit 4800 via a 1050ti into a BMD hdmi converter to 3g-SDI which plugs into my Decklink
Issue:
The video comes in crystal clear with no drops and the audio drops frames making the audio sound like it's going through a helicopter blade. This is seen and heard using vMix.
If I use another program say BMD Express or OBS the video and audio come in fine. If i use vMix and do a recording from the multicorder I get zero dropped frames on the recording and the sound is great. It's only when I record with the recorder and or simply listen to the sound on my computer and I can visually see the audio readings drop out so it's not like a speaker thing.
Things i've tried:
Even though other programs work and even vmix works via the multicorder i re-installed the GPU the Capture cards and audio drivers with no success.
I'm at a losss??? This happens the same with NDI as well. It seems to be a vmix audio issue but I see no errors or anything. what else can I check?
TomCP
#2 Posted : Tuesday, September 28, 2021 7:05:13 PM(UTC)
TomCP
Rank:: Newbie
Hey All,
Not sure if dredging up old post is the done thing.
But I am having the exact issue described above. Does anyone have any thoughts
Tom
mtone
#3 Posted : Tuesday, September 28, 2021 10:17:42 PM(UTC)
mtone
choppy audio can sometimes be a sample rate mismatch.. maybe switch your audio interface between 44.1 and 48 and see if it has any effect ?
DoyleTX
#4 Posted : Monday, May 30, 2022 12:57:06 AM(UTC)
DoyleTX
I have audio glitches on two systems (one is Decklink Duo2 and the other is Decklink 8K Pro). I can't seem to find anything that works to fix this problem. Anyone have any solutions? Sample rates match, but I've tried 44.1. I do mostly musical performance live streams and this is a major issue for me.
