Choppy Audio via Decklink Duo 2 only in vMix
Joined: 3/28/2016(UTC) Posts: 172   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
Setup:
vMix 22.0.60 4K NVIDIA 1080ti X299 i7 7820X 3.60 64GB Ram SSD (4x Samsung 970s)
Capture cards: BMD Decklink Duo 2 (latest firmware 11.2) BMD Decklink 4K
Source: Game RGB 4:4:4 16bit 4800 via a 1050ti into a BMD hdmi converter to 3g-SDI which plugs into my Decklink
Issue:
The video comes in crystal clear with no drops and the audio drops frames making the audio sound like it's going through a helicopter blade. This is seen and heard using vMix.
If I use another program say BMD Express or OBS the video and audio come in fine. If i use vMix and do a recording from the multicorder I get zero dropped frames on the recording and the sound is great. It's only when I record with the recorder and or simply listen to the sound on my computer and I can visually see the audio readings drop out so it's not like a speaker thing.
Things i've tried:
Even though other programs work and even vmix works via the multicorder i re-installed the GPU the Capture cards and audio drivers with no success.
I'm at a losss??? This happens the same with NDI as well. It seems to be a vmix audio issue but I see no errors or anything. what else can I check?
Hey All,
Not sure if dredging up old post is the done thing.
But I am having the exact issue described above. Does anyone have any thoughts
Tom
Thanks: 4 times Was thanked: 20 time(s) in 19 post(s)
choppy audio can sometimes be a sample rate mismatch.. maybe switch your audio interface between 44.1 and 48 and see if it has any effect ?
I have audio glitches on two systems (one is Decklink Duo2 and the other is Decklink 8K Pro). I can't seem to find anything that works to fix this problem. Anyone have any solutions? Sample rates match, but I've tried 44.1. I do mostly musical performance live streams and this is a major issue for me.
