NDI
Suggest Switch for Buffer memory, QoS and blocking
Joined: 6/29/2019(UTC) Posts: 2  Location: Cairo Thanks: 2 times
Hi all, This is the first time run NDI system on my own media server All i need is to capture the screen from 3-4 laptops Also i don't need latency or delaying to my system
I read more articles about the best switches but i need your support to suggest Brand and model to buy please
I found in the suggestions the switch must be with the zero "Buffer Memory" for zero latency or delaying
Also the switch must have QoS and non-block options
I don't know if i really need these options or not I don't know if i need Managed or unmanaged Switch
So please suggest Switch model for me 8 or 16 ports
Thanks for your support
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 321 times Was thanked: 263 time(s) in 233 post(s)
This is overthinking it. Switches don't themselves buffer anything substantially. At least not relative to video frame rates.
If you're not familiar with network administration a managed switch is more headache than it's worth.
Your situation would be readily handled using a simple, unmanaged switch.
Originally Posted by: mjgraves  This is overthinking it. Switches don't themselves buffer anything substantially. At least not relative to video frame rates.
Your situation would be readily handled using a simple, unmanaged switch. Can you please suggest model for me Thank you for your reply
NDI
