moha20106
#1 Posted : Saturday, June 29, 2019 12:42:49 AM(UTC)
moha20106
Egypt
Hi all,
This is the first time run NDI system on my own media server
All i need is to capture the screen from 3-4 laptops
Also i don't need latency or delaying to my system
I read more articles about the best switches but i need your support to suggest Brand and model to buy please
I found in the suggestions the switch must be with the zero "Buffer Memory" for zero latency or delaying
Also the switch must have QoS and non-block options
I don't know if i really need these options or not
I don't know if i need Managed or unmanaged Switch
So please suggest Switch model for me
8 or 16 ports
Thanks for your support
mjgraves
#2 Posted : Saturday, June 29, 2019 1:00:56 AM(UTC)
mjgraves
This is overthinking it. Switches don't themselves buffer anything substantially. At least not relative to video frame rates.
If you're not familiar with network administration a managed switch is more headache than it's worth.
Your situation would be readily handled using a simple, unmanaged switch.
moha20106 on 6/29/2019(UTC)
moha20106
#3 Posted : Saturday, June 29, 2019 1:46:21 AM(UTC)
moha20106
Egypt
Can you please suggest model for me
Thank you for your reply
mjgraves
#4 Posted : Saturday, June 29, 2019 3:46:44 AM(UTC)
mjgraves
For unmanaged switches I like Netgear: https://amzn.to/2FEmTES
