Joined: 5/14/2013(UTC) Posts: 153  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
Hi All
Currently playing with some Php scripts that take rss/ twitter news feeds and sends them at a Ticket Title using the API.
What i want to do is send the animation time for the ticker so if it is short pice of text it goes the same speed as a long block of text, i've no problem dong a word count at the php end and comming up with a time im just struggling at setting this with the api.
Cheers
Ian
Martin - Any ideas?
cheers
Ian
Sorted
used the same work around that is used in the Vmix Social and the Weather bottom 3rd's to set image source files to set the duration of the scroll, then my php counts the number of characters that are being sent to the ticker and calculates a new duration for the scroll
cheers
Ian
