Killerhands
#1 Posted : Thursday, February 27, 2014 3:56:22 PM(UTC)
Killerhands
Hey,
I'm not sure if this a bug or intended but for some reason when I have an alpha'd MOV play and I transition out of it, even though I have 'Pause after Transition' selection, it still replays the file from the beginning when it's not an output (I posted a link to a video I made to demonstrate it). This is a big issue especially when I want to go back to the Alpha'd MOV it glitches for a frame, since it's in the middle of replaying the file, on the output and makes it pretty much unusable in a live production.
Dropbox link: https://db.tt/4nSZzGc5
Thanks,
Killerhands
Killerhands
#2 Posted : Friday, February 28, 2014 7:25:25 PM(UTC)
Killerhands
After playing around with it a little more I've isolated the issue to 64-bit vMix ONLY.
Everything works as intended in 32-bit (It doesn't replay the animation when I transition off of the MOV).
#3 Posted : Friday, February 28, 2014 10:37:29 PM(UTC)
Thanks for pointing that out, it will be fixed in the final 12 release.
#4 Posted : Sunday, March 2, 2014 7:17:09 AM(UTC)
Try the update below, it should resolve the issue:
http://forums.vmix.com.au/default.aspx?g=posts&m=8401#post8401
Killerhands on 3/3/2014(UTC)
Killerhands
#5 Posted : Monday, March 3, 2014 10:11:17 PM(UTC)
Killerhands
Thanks so much Martin! I'll try it when I get into work tomorrow!
