Hey, I'm not sure if this a bug or intended but for some reason when I have an alpha'd MOV play and I transition out of it, even though I have 'Pause after Transition' selection, it still replays the file from the beginning when it's not an output (I posted a link to a video I made to demonstrate it). This is a big issue especially when I want to go back to the Alpha'd MOV it glitches for a frame, since it's in the middle of replaying the file, on the output and makes it pretty much unusable in a live production. Dropbox link: https://db.tt/4nSZzGc5Thanks, Killerhands
After playing around with it a little more I've isolated the issue to 64-bit vMix ONLY.
Everything works as intended in 32-bit (It doesn't replay the animation when I transition off of the MOV).
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Thanks for pointing that out, it will be fixed in the final 12 release.
Martin vMix
Thanks so much Martin! I'll try it when I get into work tomorrow!
