cambysys
#1 Posted : Saturday, February 22, 2014 8:55:30 AM(UTC)
cambysys
I bought a Pinacle Dazzle DVD Recorder HD.
On the device it says it is DVC100 1.1
When I tried to add it as an input I get an error
"Capture resolution is not supported by this device"
It then advises
AddNewInput. The following are supported
640x480 PAL 50i or 25p YUY2
640x480 NTSC 59.94i or 29.97p YUY2
320x240 PAL 50i or 25p YUY2
320x240 NTSC 59.94i or 29.97p YUY2
Something just does not seem right here. On the box it indicates HD?
Anyone had any experience with the Dazzle.
sontoloyo
#2 Posted : Saturday, February 22, 2014 10:13:14 AM(UTC)
sontoloyo
Malaysia
Have you already tried:
Resolution = 720x576
Frame rate = PAL 50i or 25p
input = Composite input
Video Format= Default
or
Frame rate = NTSC 59.94i or 29.97p
thanks 1 user thanked sontoloyo for this useful post.
cambysys on 2/25/2014(UTC)
cambysys
#3 Posted : Tuesday, February 25, 2014 5:56:33 AM(UTC)
cambysys
or
Now it works for 720x576
Hmmm
Thank you for the pointer.
Guest (4)
