I bought a Pinacle Dazzle DVD Recorder HD. On the device it says it is DVC100 1.1
When I tried to add it as an input I get an error "Capture resolution is not supported by this device" It then advises AddNewInput. The following are supported
640x480 PAL 50i or 25p YUY2 640x480 NTSC 59.94i or 29.97p YUY2 320x240 PAL 50i or 25p YUY2 320x240 NTSC 59.94i or 29.97p YUY2
Something just does not seem right here. On the box it indicates HD?
Anyone had any experience with the Dazzle.
Joined: 7/6/2013(UTC) Posts: 45   Location: Slangor Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Have you already tried:
Resolution = 720x576 Frame rate = PAL 50i or 25p input = Composite input Video Format= Default
or
Resolution = 720x576 Frame rate = NTSC 59.94i or 29.97p input = Composite input Video Format= Default
 1 user thanked sontoloyo for this useful post.
sontoloyo wrote:Have you already tried:
or
Now it works for 720x576 Hmmm Thank you for the pointer.
