wireless multi cam with no wifi
Joined: 8/3/2013(UTC) Posts: 48  Location: Florida Thanks: 19 times Was thanked: 1 time(s) in 1 post(s)
I have a fairly robust machine running vmix and I am feeding the main camera into it with a BMD Intensity Pro card but where I am streaming my event I have no traditional internet service so I am using a iPhone as a hotspot. I know this is not really a reliable or prescribed method but I have been doing it for 3 years now and I am in Tampa Florida with a fast LTE tower right next to me and believe it or not I can stream a 12 hour event without interruption. My problem is this, I have recently purchased 2 Teradek Cube encoders and I would like to ingest feeds from 2 wireless cameras as well, typically you would just put these 2 encoders on the same wireless network you were streaming over and vmix picks them up fine however my wireless network is a iPhone and I don't want to put my stream at risk with the phone handling the stream and serving as a hotspot for 2 ip streams. Any other thoughts on how to get vmix to ingest these 2 wireless cameras?
Joined: 5/27/2013(UTC) Posts: 28 Location: Battle Creek, MI
We use a cradlepoint router to connect to use our hotspot as a gateway and it also is our main network router interconnecting our encoders, ip cameras, etc. http://www.cradlepoint.c...cts/routing-and-failoverWe use the MBR 1400 without the add on bridge. It connects to wifi hotspots and will use them as a gateway while it maintains the security behind the wall.
Joined: 1/29/2014(UTC) Posts: 24  Location: Las Angeles, CA Was thanked: 3 time(s) in 3 post(s)
Which Carrier do you use? Which Plan? How much is the plan per month?
I have been with AT&T for the past few years mostly in Florida. They are consistently the fastest and most reliable. I have tried verizon some and they do t even compare. I usually have around a 15gb plan but change it ocassionally based on how much streaming I am doing. Use a samsung Gs4 and a iPhone 5s. I think the plan now runs around $130 that I have. Believe it or not I have streamed 4 day event 15 hours a day without dropping the webcast a single time on att
