ebjorno
#1 Posted : Wednesday, June 26, 2019 9:04:14 PM(UTC)
ebjorno
Hi. This function for decreasing volume incrementally works Function=SetVolume&Input=3&Value=-=5 but the same function for increasing does not work in Scripting Function=SetVolume&Input=3&Value=+=5, although +=5 works for incrementally increasing the audio if it is done with Shortcuts. Is it a bug or am I doing something wrong?
ebjorno
#2 Posted : Friday, September 20, 2019 6:41:09 PM(UTC)
ebjorno
SOLUTION:
The script has to use Unicode coding for the (=, + and -)
= is 3D
+ is 2B
- is 2D
Examples:
Function=SetPanX&Value=%2B%3D0.01&Input=24
Pans input 24 to the right for 0.01 units
Function=SetPanX&Value=%2D%3D0.01&Input=24
Pans input 24 to the left for 0.01 units
