SetVolume function (increment) - solved
Hi. This function for decreasing volume incrementally works Function=SetVolume&Input=3&Value=-=5 but the same function for increasing does not work in Scripting Function=SetVolume&Input=3&Value=+=5, although +=5 works for incrementally increasing the audio if it is done with Shortcuts. Is it a bug or am I doing something wrong?
Originally Posted by: ebjorno  Hi. This function for decreasing volume incrementally works Function=SetVolume&Input=3&Value=-=5 but the same function for increasing does not work in Scripting Function=SetVolume&Input=3&Value=+=5, although +=5 works for incrementally increasing the audio if it is done with Shortcuts. Is it a bug or am I doing something wrong? SOLUTION: The script has to use Unicode coding for the (=, + and -) = is 3D + is 2B - is 2D Examples: Function=SetPanX&Value=%2B%3D0.01&Input=24 Pans input 24 to the right for 0.01 units Function=SetPanX&Value=%2D%3D0.01&Input=24 Pans input 24 to the left for 0.01 units
