Activator for Script that is running
Joined: 10/30/2018(UTC) Posts: 11  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
I have written a script in a shortcut that presets and transitions to several cameras in sequence, while overlaying and changing data rows a dynamic graphic. Is there way to use an activator on an xKeys 128 Tbar, to have the shortcut button blink while the script is running?
I don't see anything under EVENT that would correspond to a script. Thx!
Joined: 1/30/2017(UTC) Posts: 5 Location: Winnipeg MB Canada
I have something similar so maybe this will help for you,
If you're not using all 4 overlays you could add a second shortcut on the same button that starts the script to put up overlay 4 with a transparent layer and set the activator to [if transparent layer is in overlay slot 4, blink X button] - then have the script end (or shortcut that ends the script) also take overlay 4 down.
 1 user thanked Jeremy G for this useful post.
Fantastic idea. Can’t wait to try it. Thx for thinking outside the box
