Peter1000
#1 Posted : Tuesday, June 11, 2019 5:37:15 PM(UTC)
Peter1000
Switzerland
Was thanked: 82 time(s) in 62 post(s)
hi there
i create a stream in a VMIX computer to an nginx server.
in vlc i can see the stream live on different computers in the network.
rtmp:/192.168.10.102/live/123456
i try to receive the stream on a second vmix system. but vmix always comes with error messages:
-Invalid Port
i am a complete streaming newbie, i tried all sort of ports 80, 8080, 5000. 1935,which is noted in the nginx server as the listen port.
Thanks for an advice.
P.
Siroki
#2 Posted : Tuesday, June 11, 2019 7:19:10 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Originally Posted by: Peter1000 Go to Quoted Post
hi there
-Invalid Port
P.
You are missing /
rtmp://192.168.10.102/live/123456
what you see in vlc you should see in vMix. Paste your rtmp link here from vlc
right should be something like this
rtmp://192.168.10.102:8080/live/123456
Or pm me and give teamviewer access
Peter1000
#3 Posted : Tuesday, June 11, 2019 8:37:44 PM(UTC)
Peter1000
Switzerland
It works now with the port option in the adress, as SIROKI mentioned. (thanks)
sorry, i was typing it wrong here in my post.
i was putting the same link in vmix, as in vlc.
i installed VLC for VMIX and there it works with this port option
rtmp://192.168.10.102:1935/live/123456
and the option VLCrtmp
all other options are not working, alwways gives a PORT error.
i try now to change the port in NGINX
elvis55
#4 Posted : Wednesday, June 12, 2019 4:48:43 PM(UTC)
elvis55
Switzerland
What is the reason to do it in the local network, from VMix to Vmix with RTMP?
Why not with NDI?
Greeting
Guest (5)
