Joined: 1/25/2019(UTC) Posts: 331  Thanks: 23 times Was thanked: 84 time(s) in 64 post(s)
hi there i create a stream in a VMIX computer to an nginx server. in vlc i can see the stream live on different computers in the network. rtmp:/192.168.10.102/live/123456
i try to receive the stream on a second vmix system. but vmix always comes with error messages: -Invalid Port
i am a complete streaming newbie, i tried all sort of ports 80, 8080, 5000. 1935,which is noted in the nginx server as the listen port.
Thanks for an advice.
P.
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
Originally Posted by: Peter1000  hi there i create a stream in a VMIX computer to an nginx server. in vlc i can see the stream live on different computers in the network. rtmp:/192.168.10.102/live/123456
P. You are missing / rtmp://192.168.10.102/live/123456 what you see in vlc you should see in vMix. Paste your rtmp link here from vlc right should be something like this rtmp://192.168.10.102:8080/live/123456 Or pm me and give teamviewer access
It works now with the port option in the adress, as SIROKI mentioned. (thanks)
sorry, i was typing it wrong here in my post. i was putting the same link in vmix, as in vlc. rtmp://192.168.10.102/live/123456
i installed VLC for VMIX and there it works with this port option rtmp://192.168.10.102:1935/live/123456 and the option VLCrtmp all other options are not working, alwways gives a PORT error.
i try now to change the port in NGINX
What is the reason to do it in the local network, from VMix to Vmix with RTMP? Why not with NDI?
Greeting
