Livegig Ltd
#1 Posted : Saturday, June 8, 2019 5:54:51 PM(UTC)
Livegig Ltd
Nigeria
Hello
Please how can i connect wireless mic to vmix for live streaming
RGD
Frank
Peter1000
#2 Posted : Saturday, June 8, 2019 9:39:46 PM(UTC)
Peter1000
Switzerland
Was thanked: 86 time(s) in 66 post(s)
Buy a USB Audio Interface, for example the cheapest Mono Interface with XLR and Mic Input, Behringer UM2, around 30$ or a better one with 4 XLR ins, Behringer U-Phoria UMC404 HD.
The Interface shows up as VMIX Audio Input.
You can also use the Line Outs of the interface, to route the 2 aditional Audio Buses in VMIX , A & B or Main out.
Livegig Ltd
#3 Posted : Saturday, June 8, 2019 9:53:51 PM(UTC)
Livegig Ltd
Nigeria
Thanks Peter1000. Iam new to live streaming and Audio connection.Can you please explain further how i will connect the wireless microphone to the interface and then to vmix?
Joeboe
#4 Posted : Sunday, June 9, 2019 12:31:40 AM(UTC)
Joeboe
This is what I do before buying any devices...I go and google it, and search for the user or owner manual, download it, and read it carefully , then make my decision on buying.....it is better that way, you get quicker answers, and you get to keep the download for future reference.....a USB interface is just an audio mixer that connects via the usb port .....you can get from a single input upwards....go google search and get some insight on these things, like I said, it is much quicker, and you have more persons to help.....
Mari
#5 Posted : Sunday, June 9, 2019 3:02:17 AM(UTC)
Mari
Netherlands
You simply connect the wireless mic to the USB Audio Interface which is connected via USB to your computer. In vMix you can add an input, there you select the USB Audio device.
