Hello Please how can i connect wireless mic to vmix for live streaming
RGD Frank
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Buy a USB Audio Interface, for example the cheapest Mono Interface with XLR and Mic Input, Behringer UM2, around 30$ or a better one with 4 XLR ins, Behringer U-Phoria UMC404 HD. The Interface shows up as VMIX Audio Input. You can also use the Line Outs of the interface, to route the 2 aditional Audio Buses in VMIX , A & B or Main out.
Originally Posted by: Peter1000  Buy a USB Audio Interface, for example the cheapest Mono Interface with XLR and Mic Input, Behringer UM2, around 30$ or a better one with 4 XLR ins, Behringer U-Phoria UMC404 HD. The Interface shows up as VMIX Audio Input. You can also use the Line Outs of the interface, to route the 2 aditional Audio Buses in VMIX , A & B or Main out. Thanks Peter1000. Iam new to live streaming and Audio connection.Can you please explain further how i will connect the wireless microphone to the interface and then to vmix?
This is what I do before buying any devices...I go and google it, and search for the user or owner manual, download it, and read it carefully , then make my decision on buying.....it is better that way, you get quicker answers, and you get to keep the download for future reference.....a USB interface is just an audio mixer that connects via the usb port .....you can get from a single input upwards....go google search and get some insight on these things, like I said, it is much quicker, and you have more persons to help.....
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
Originally Posted by: Livegig Ltd  Thanks Peter1000. Iam new to live streaming and Audio connection.Can you please explain further how i will connect the wireless microphone to the interface and then to vmix?
You simply connect the wireless mic to the USB Audio Interface which is connected via USB to your computer. In vMix you can add an input, there you select the USB Audio device.
