thsorensen1
#1 Posted : Friday, June 7, 2019 4:02:59 PM(UTC)
thsorensen1
Norway
Hi.
If I have 4 instant replay channels, is it somehow possible to show all of them in a multiviewer?
By default I can only see 2 (rec A and B).
Thomas
desmar
#2 Posted : Wednesday, June 12, 2019 7:41:14 AM(UTC)
desmar
Canada
Was thanked: 76 time(s) in 57 post(s)
From my understanding.
Instant replay can record up to 4 camera inputs/angles,
But there are only 2 replay bus, A Bus, and B Bus if I'm correct.
And in each bus you can select one of the 4 camera/angles.
So to answer your question there is only 2 replay bus you can use.
@admin could clarify this if I am wrong.
Originally Posted by: thsorensen1 Go to Quoted Post
Hi.
Thomas
bgbenni
#3 Posted : Wednesday, June 12, 2019 7:31:38 PM(UTC)
bgbenni
This is right but I hope in the next big video replay update it’s coming that we can see all 4 channels
Radiotvpat1982
#4 Posted : Tuesday, June 18, 2019 12:21:51 AM(UTC)
Radiotvpat1982
You should be seeing on one screen 4 camera angles coming in and 2 outputs going out. Is this not what you are seeing? vMixReplayHighlightReels.jpg (127kb) downloaded 0 time(s).
thsorensen1
#5 Posted : Friday, July 5, 2019 6:26:24 PM(UTC)
thsorensen1
Norway
I can see all four incoming cameras live, but when I scrub the timeline in the replay, I can only see two recordings back in time (bus A and B).
Hopefully some of the next updates of vMix will handle 4 preview outputs as well :)
Radiotvpat1982
#6 Posted : Saturday, July 6, 2019 11:21:37 AM(UTC)
Radiotvpat1982
Are you in live mode or edit mode? I have shortcuts built but I typically select select an angle before backing it up or I used a preset like -5 for basketball. Try putting it in edit mode then scrubbing back.
