Instant Replay
4 instant replay in multiviewer?
Joined: 5/29/2019(UTC) Posts: 4  Location: Tromsø Was thanked: 3 time(s) in 1 post(s)
Hi.
If I have 4 instant replay channels, is it somehow possible to show all of them in a multiviewer?
By default I can only see 2 (rec A and B).
-- Thomas
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
From my understanding. Instant replay can record up to 4 camera inputs/angles, But there are only 2 replay bus, A Bus, and B Bus if I'm correct. And in each bus you can select one of the 4 camera/angles. So to answer your question there is only 2 replay bus you can use. @admin could clarify this if I am wrong. Originally Posted by: thsorensen1  Hi.
-- Thomas
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
This is right but I hope in the next big video replay update it’s coming that we can see all 4 channels
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 15 time(s) in 11 post(s)
You should be seeing on one screen 4 camera angles coming in and 2 outputs going out. Is this not what you are seeing?  vMixReplayHighlightReels.jpg (127kb) downloaded 0 time(s).
Originally Posted by: Radiotvpat1982  You should be seeing on one screen 4 camera angles coming in and 2 outputs going out. Is this not what you are seeing?  vMixReplayHighlightReels.jpg (127kb) downloaded 0 time(s). I can see all four incoming cameras live, but when I scrub the timeline in the replay, I can only see two recordings back in time (bus A and B). Hopefully some of the next updates of vMix will handle 4 preview outputs as well :)
Are you in live mode or edit mode? I have shortcuts built but I typically select select an angle before backing it up or I used a preset like -5 for basketball. Try putting it in edit mode then scrubbing back.
Instant Replay
