kentenal
#1 Posted : Friday, May 31, 2019 9:44:18 AM(UTC)
kentenal
I'm looking at the AT&T Nighthawk LTE Mobile Hotspot Router for some Facebook live video that's out in the country. I was wondering if anyone has used the device and if it worked OK for them. My son and I do video for a truck and tractor pulling group. We usually just mount his cell phone on his video camera but wanted to try to upgrade our coverage. I can't rent this or get it on a trial basis. AT&T says I can buy and try it and then I can return it if I don't like (for a restocking fee).
Here's my son's YouTube page (with tractor pulling videos). He's autistic but loves the sport.
Turbocharged Pulling Videos
Thanks,
Chris
kevev
#2 Posted : Tuesday, June 4, 2019 2:21:07 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Hi Chris. If you want to save $ this is what we did.
Purchase LTE router:(it has Erhernet & Wifi)
https://www.att.com/buy/...less-internet-black.html
Add $20 voice plan
Add $40 50GB/month data plan.
kentenal
#3 Posted : Tuesday, June 4, 2019 2:47:14 AM(UTC)
kentenal
Thanks! The area we usually pull at (where we want to use this) has around 2 to 3 bars of coverage. Do you think it's enough to use this router with VMix?
kevev
#4 Posted : Tuesday, June 4, 2019 2:59:15 AM(UTC)
kevev
What bitrate are you planning on transmitting? Have you performed an internet speedtest on AT&T at this location? If so, what is your upload bandwidth?
kentenal
#5 Posted : Tuesday, June 4, 2019 9:37:34 AM(UTC)
kentenal
I use the H264 720p 1.5 mbps AAC 128kbps setting on our Sunday Night show. I've got no clue on my upload speed in the field. I'll have to check at our next pull.
kevev
#6 Posted : Tuesday, June 4, 2019 9:42:08 AM(UTC)
kevev
You should be good. AT&T has LTE everywhere.
kentenal
#7 Posted : Wednesday, June 5, 2019 4:45:25 AM(UTC)
kentenal
Thank you!
Guest (4)
