Ciao a tutti, ho acquistato VMIX in licenza per ora ho collegato delle webcam della Microsoft. Ora vorrei collegare una Videocamera della Sony la HDR PJ410 ma per ora non riesco. Uso un adattatore della Logylync che esce dal PC in USB 3.0 e diventa HDMI . Dalla telecamera esco con il cavo apposito della sony che parte in micro HDMI e finisce in HDMI normale ma non va !! Avete consigli da darmi ?? potete darmi una mano ?? Il tutto su un PC con Windows 10 pro. GRAZIE in anticipo .
Diego.
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 69 Location: Canada
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Hi Diego, Please note, webcams can connect via USB, but conventional video cameras will require a capture device of some sort. (HDMI ports on laptops and GPUs are for Output only) A list of supported devices can be found on the vMix website here: https://www.vmix.com/sof...are.aspx#capturehardwareI hope that helps. vMixGreg
Originally Posted by: vmixgreg  Hi Diego, Please note, webcams can connect via USB, but conventional video cameras will require a capture device of some sort. (HDMI ports on laptops and GPUs are for Output only) A list of supported devices can be found on the vMix website here: https://www.vmix.com/sof...are.aspx#capturehardwareI hope that helps. vMixGreg Thank You very much . Bye Diego
