Diegone
#1 Posted : Wednesday, May 29, 2019 9:51:10 PM(UTC)
Diegone
Italy
Ciao a tutti,
ho acquistato VMIX in licenza per ora ho collegato delle webcam della Microsoft.
Ora vorrei collegare una Videocamera della Sony la HDR PJ410 ma per ora non riesco.
Uso un adattatore della Logylync che esce dal PC in USB 3.0 e diventa HDMI .
Dalla telecamera esco con il cavo apposito della sony che parte in micro HDMI e finisce in HDMI normale ma non va !!
Avete consigli da darmi ?? potete darmi una mano ??
Il tutto su un PC con Windows 10 pro.
GRAZIE in anticipo .
Diego.
vmixgreg
#2 Posted : Wednesday, May 29, 2019 11:45:14 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Hi Diego,
Please note, webcams can connect via USB, but conventional video cameras will require a capture device of some sort.
(HDMI ports on laptops and GPUs are for Output only)
A list of supported devices can be found on the vMix website here:
https://www.vmix.com/sof...are.aspx#capturehardware
I hope that helps.
vMixGreg
Diegone
#3 Posted : Thursday, May 30, 2019 12:25:45 AM(UTC)
Diegone
Italy
Originally Posted by: vmixgreg Go to Quoted Post
Hi Diego,
I hope that helps.
vMixGreg
Thank You very much .
Bye
Diego
