carlosx8664
#1 Posted : Wednesday, May 29, 2019 12:29:28 AM(UTC)
carlosx8664
Ghana
Hello
Is there a way I can trigger the MERGE event by time? Say it will MERGE at 10:30am for 60 seconds, 12pm at 30 seconds, etc...
Will I also be able to log this information into a text file?
Carlos
vmixgreg
#2 Posted : Thursday, May 30, 2019 12:14:28 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
Hi Carlos,
vMix only allows Transition effects on the following Triggers:
- OnCompletion (for videos)
- OnCountdownCompleted (for countdown timers)
Since vMix does not recognize a time-of-day countdown as an actual timer (the computer clock doesn't stop), you would need to set-up an actual countdown timer (or series of timers) and start them appropriately to synchronize with the time-of-day you want the Trigger to "fire" (i.e. start a 30 minute timer at 10:00 am for a 10:30 am Merge Transition).
Unfortunately, vMix is not designed as a "Playout System" and so does not log such things into a text file.
I hope that helps to answer your question.
vMixGreg
