RJF
#1 Posted : Friday, May 17, 2019 8:18:41 AM(UTC)
RJF
Dear all,
I was happy to test today Vmix22 with the ClickShare CSE-200 wireless system.
With this system, you are able to wireless broadcast to a large screen / TV in a conference room (and even switch with a button from one computer to another). See description.
I used the latest Clicshare drivers and was able to wireless broadcast using the extended desktop product option, image & video was ok but unfortunately NO Sound appeared using Vmix.
Strangely enough, I could listen to the song when it was launch directly from VLC (and some other software).
I checked eveything in Audio Output, relaunched many times the soft, read and followed Clickshare Knowledge Base recommendations but still No Sound...
So now there is this ClickShare KB article : Audio of some applications like Audicity and Fidelius does not work [KB3886] where it is say :
The audio of some applications like Audicity and Fidelius does not work.
This is usually related to the sample rate.
Check if the application allows for you to set a sample rate.
ClickShare supported sample rate:Radio quality 16-bit 22 KHz
Here's my questions :
  • Does Vmix support 16-bit 22 KHz or only 44.1khz or 48khz ?
  • Is Vmix compatible -OR NOT- with ClickShare ?
  • Any tricks or help ?
I thank you very much for any suggestions !
