Hardware Compatibility
Vmix and ClickShare Wireless System
Joined: 12/4/2016(UTC) Posts: 18   Location: Strasbourg Thanks: 3 times
Dear all, I was happy to test today Vmix22 with the ClickShare CSE-200 wireless system. With this system, you are able to wireless broadcast to a large screen / TV in a conference room (and even switch with a button from one computer to another). See description. I used the latest Clicshare drivers and was able to wireless broadcast using the extended desktop product option, image & video was ok but unfortunately NO Sound appeared using Vmix. Strangely enough, I could listen to the song when it was launch directly from VLC (and some other software). I checked eveything in Audio Output, relaunched many times the soft, read and followed Clickshare Knowledge Base recommendations but still No Sound... So now there is this ClickShare KB article : Audio of some applications like Audicity and Fidelius does not work [KB3886] where it is say : The audio of some applications like Audicity and Fidelius does not work. This is usually related to the sample rate. Check if the application allows for you to set a sample rate.
ClickShare supported sample rate:Radio quality 16-bit 22 KHzHere's my questions : - Does Vmix support 16-bit 22 KHz or only 44.1khz or 48khz ?
- Is Vmix compatible -OR NOT- with ClickShare ?
I thank you very much for any suggestions !
