Henny
#1 Posted : Friday, May 10, 2019 7:25:10 PM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
Morning all, im trying to Bring in an HTML table as a data source, see https://footballctrl.000....com/SCORES_FOR_VMIX.php
first off which source type do you use for HTML tables, ive tried them all, second is there something wrong with the formatting of my HTML ?
thanks
ian
mavik
#2 Posted : Friday, May 10, 2019 7:34:38 PM(UTC)
mavik
It seems that you create the table dynamically with a php script. If I were you I would create a file (csv) by that script instead of a html formatted human readable page. It needs to be in a machine readable format.
Referencing the dynamicly created csv would work in vMix.
Henny
#3 Posted : Friday, May 10, 2019 7:59:03 PM(UTC)
Henny
yep just had the same idea after i started this post
https://footballctrl.000.../SCORES_FOR_VMIx_csv.php
but apparently vmix supports HTML tables , https://www.vmix.com/hel...tm?DataSourcesTypes.html
