Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Morning all, im trying to Bring in an HTML table as a data source, see https://footballctrl.000....com/SCORES_FOR_VMIX.phpfirst off which source type do you use for HTML tables, ive tried them all, second is there something wrong with the formatting of my HTML ? thanks ian
It seems that you create the table dynamically with a php script. If I were you I would create a file (csv) by that script instead of a html formatted human readable page. It needs to be in a machine readable format. Referencing the dynamicly created csv would work in vMix.
