RickW
#1 Posted : Wednesday, April 24, 2019 7:07:34 AM(UTC)
RickW
I would like to know if the maximum number of outputs can be increased?
Are all of the outputs the same video? or can i play a separate video on each output?
My goal is to broadcast a different video to multiple screens in different parts of the building, using vMix as a server. for example.
Room 1 -> video 1 with its own title
Room 2 -> video 2 with its own title
Room 3 -> video 3 with its own title
Room 4 -> video 4 with its own title
Room 5 -> video 4 with its own title
I have spent 6 hours on this forum and can't locate a similar question
thank you
MycroBeat99
#2 Posted : Wednesday, April 24, 2019 11:35:51 AM(UTC)
MycroBeat99
Romania
For a multiple screens i think you can output only 2.
You can output 4 NDI and 2 External with vMix with own video/image + audio via Busses.
I believe the solution for you is to virtualize a server with 2 virtual machines with windows and install vmix there. Or you can use another software like OBS or StreamLabs + Graphics via After Effects in alpha looping (if there a static graphics almost all the time or prepare the graphics before) and output via NDI.
Then use a Windows Tablet/Laptop to project NDI via Newtek Studio Monitor.
Or you can use multiple graphics card to project on screens from server with virtual machines, but I think it's too expensive.
Be creative!
thanks 1 user thanked MycroBeat99 for this useful post.
RickW on 4/25/2019(UTC)
mavik
#3 Posted : Wednesday, April 24, 2019 3:45:09 PM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
vMix is more or less a single program output. You have options for more outputs of sources or multiview but it will only be a single program that you can mix. Doing seperate and indipendent programs for 5 rooms you would need 5 times the setup.
Taking the costs for 5 setups with software, hardware and capture cards I would recommend taking a look at the Ross carbonate ultra hardware mixer. That offers multiple M/E a lot of inputs and outputs and starts at 10k$ roughly.
