Peter1000
#1 Posted : Sunday, April 21, 2019 10:18:37 PM(UTC)
Peter1000
Switzerland
Was thanked: 87 time(s) in 67 post(s)
Hi
with the possibility to use for example Streamdeck external Keypads, i would like to have more toggle shortcuts, like PlayPause. With only 6 or 15 Keys on the pad, i could safe a lot of keys.
-Startstream/Stopstream (with option 1-3 or all)
-Startrecord/Stoprecord
-Loopon/Loopoff
like you have it allready with the toggle options for Audio, BusAAudio, BusBaudio etc.
maybe there are more, but these 3 options i could really use often.
Thank you for checking these options.
Peter
raugert
#2 Posted : Tuesday, April 23, 2019 1:37:03 AM(UTC)
raugert
Canada
StartStopStreaming and StartStopRecording already exist as "toggle" shortcuts. You can also select the stream in the Value field.
Loop On/Off doesn't appear to exist as a shortcut.
Peter1000
#3 Posted : Tuesday, April 23, 2019 6:09:38 AM(UTC)
Peter1000
Switzerland
@raugert
thanks! i must be blind sometimes....
ovinas
#4 Posted : Tuesday, April 23, 2019 3:05:33 PM(UTC)
ovinas
+1
This and other missing shortcuts and activators were already brought up many times but unfortunately these small improvements and additions have low to none priority.
