Joined: 1/25/2019(UTC) Posts: 331  Thanks: 23 times Was thanked: 84 time(s) in 64 post(s)
Hi with the possibility to use for example Streamdeck external Keypads, i would like to have more toggle shortcuts, like PlayPause. With only 6 or 15 Keys on the pad, i could safe a lot of keys. -Startstream/Stopstream (with option 1-3 or all) -Startrecord/Stoprecord -Loopon/Loopoff like you have it allready with the toggle options for Audio, BusAAudio, BusBaudio etc.
maybe there are more, but these 3 options i could really use often. Thank you for checking these options.
Peter
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
StartStopStreaming and StartStopRecording already exist as "toggle" shortcuts. You can also select the stream in the Value field.
Loop On/Off doesn't appear to exist as a shortcut.
@raugert thanks! i must be blind sometimes....
+1
This and other missing shortcuts and activators were already brought up many times but unfortunately these small improvements and additions have low to none priority.
