FrankLeggett
#1 Posted : Tuesday, April 2, 2019 12:12:07 AM(UTC)
FrankLeggett
I am getting a GPU Overload message on loading. I am not using any inputs at the moment. I have a ROG i7 laptop with a 1060 Graphics card. I have uploaded to support my error log.
Please can you help I have never been able to get VMix to work on this laptop on a job only in the office on test.
FrankLeggett
#2 Posted : Friday, April 5, 2019 10:25:44 PM(UTC)
FrankLeggett
OK I think I might have a reason for the issues. I noticed that I was getting a GPU overload but at the time I was running on battery and not on mains power. I will have to experiment to see if this happens again.
Is there a way to run VMix on the laptop battery power only, I understand that it won't last long.
jvphobic
#3 Posted : Friday, April 5, 2019 11:15:36 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
Make sure that you check your power settings in Windows. Many laptops by default are set to lower or turn off more power hungry features when on battery power. You can change those settings in the power panel of Windows. Set it to maximum performance. Your laptop will die quicker, but you should get the full resources out of it as well.
FrankLeggett
#4 Posted : Friday, April 5, 2019 11:32:12 PM(UTC)
FrankLeggett
Thanks, there was I thinking it would be something hard to find in the NVidia Control panel but of course just look at the windows power settings.
Barney Box Lane
#5 Posted : Saturday, April 6, 2019 6:17:17 PM(UTC)
Barney Box Lane
what's a good number for gpu memory?
I'm hoping being at 90% means it's being used optimally and not on the brink of maxing out :/
Guest (4)
Similar Topics
GPU Overload and Stuttering while recording & streaming (Hardware Compatibility)
by Binat 5/15/2023 9:13:58 PM(UTC)
GPU overload or insufficient router? (NDI)
by Gerrit Grobler 6/8/2022 6:13:50 PM(UTC)
GPU overload warning (Hardware Compatibility)
by PreconVirtual 5/4/2021 1:27:51 AM(UTC)
GPU overload!!! (General Discussion)
by RogerBlu 4/19/2021 6:22:35 AM(UTC)
GPU Overloaded on the 3090 (General Discussion)
by geekslife 3/26/2021 10:48:40 PM(UTC)
Gpu overload desktop 3070, (General Discussion)
by nutronik 3/14/2021 6:36:10 AM(UTC)
GPU overload Nvidia (General Discussion)
by kevev 3/11/2021 8:39:56 PM(UTC)
GPU Overloads with GTX 1650 // UHD 630 (General Discussion)
by jogyth 2/21/2021 6:52:01 PM(UTC)
GPU Overload due to Lower Thirds using 3% GPU Mem each (General Discussion)
by dec33 2/6/2021 9:45:12 AM(UTC)
GPU overloaded when adding prerecorded video to live stream (General Discussion)
by m_elias 1/12/2021 12:09:30 PM(UTC)
GPU Overloaded at 48% (General Discussion)
by Geoff B 7/15/2020 9:07:57 AM(UTC)
GPU Overload with RTX2080 (General Discussion)
by seb666 6/24/2020 6:06:42 AM(UTC)
GPU Overload, first time ever on this computer (Hardware Compatibility)
by KnKproductions 6/21/2020 10:45:40 AM(UTC)
Streaming all day - GPU overload drop frames over time and crash (General Discussion)
by tsulls 6/13/2019 9:40:17 AM(UTC)
GPU Overload and Long Render Times (Hardware Compatibility)
by JohnnyFlash 11/1/2018 8:24:54 AM(UTC)
