davidthornburrow@gmail.com
#1 Posted : Thursday, March 28, 2019 10:18:41 AM(UTC)
Canada
Hi there,
I am running vMix while controlling two PTZOptics G2 cameras.
I also have a X-Keys control pad that I use to select pre-programmed camera shots.
I would like to create pre-programmed camera movements, like panning across a room.
Possibly you would select the "pan" button once to set up the shot and then select again to engage the movement.
Anyone know how this can be done? has anyone done it before?
Thanks very much,
Dave.
phab
#2 Posted : Friday, March 29, 2019 11:01:48 PM(UTC)
phab
Hi Dave,
I had already mentioned and it would be great if they add this option ;)
https://forums.vmix.com/posts/t18153-Camera-PTZ-and-motion-control
+1
best regard,
Phab
#3 Posted : Saturday, March 30, 2019 11:51:24 PM(UTC)
Canada
I had a couple messages about creating virtual inputs to do my panning.
This would be a good method if you could slow the camera movement down when panning between the camera positions. Is there a way to slow down camera movements for some virtual inputs while leaving the others fast?
