Programming Camera Movements
Hi there, I am running vMix while controlling two PTZOptics G2 cameras. I also have a X-Keys control pad that I use to select pre-programmed camera shots. I would like to create pre-programmed camera movements, like panning across a room. Possibly you would select the "pan" button once to set up the shot and then select again to engage the movement. Anyone know how this can be done? has anyone done it before?
Thanks very much, Dave.
I had a couple messages about creating virtual inputs to do my panning. This would be a good method if you could slow the camera movement down when panning between the camera positions. Is there a way to slow down camera movements for some virtual inputs while leaving the others fast?
