Bird01
#1 Posted : Wednesday, March 6, 2019 5:09:01 AM(UTC)
Bird01
Hi All
The audio vMix is receiving can't be heard on a master output.
I can see the audio bars jumping in vMix so I know it is receiving the audio. I can even hear it over the internet when I live stream video. But I cannot hear the audio coming out of the computer. Neither the headphone jack or the connections on my motherboard.
When I play an overlay with sound using VLC I can hear the audio fine. I have the master output of vMix set to windows default devices.
Any ideas?
zenvideo
#2 Posted : Wednesday, March 6, 2019 7:56:30 AM(UTC)
zenvideo
Have you tried setting it to a specific device?
Barney Box Lane
#3 Posted : Wednesday, March 6, 2019 8:48:25 PM(UTC)
Barney Box Lane
Click on the speaker and check it's set to your main speakers, sometimes my computer will still be set to headphone out after unplugging them or if you've hooked up a Bluetooth speaker to it.
another is check that one of your inputs isn't on solo which would silence everything else on that pc
