No Audio Output - vMix Master
Hi All
The audio vMix is receiving can't be heard on a master output.
I can see the audio bars jumping in vMix so I know it is receiving the audio. I can even hear it over the internet when I live stream video. But I cannot hear the audio coming out of the computer. Neither the headphone jack or the connections on my motherboard.
When I play an overlay with sound using VLC I can hear the audio fine. I have the master output of vMix set to windows default devices.
Any ideas?
Joined: 5/13/2014(UTC) Posts: 521   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Originally Posted by: Bird01  I have the master output of vMix set to windows default devices. Have you tried setting it to a specific device?
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
Click on the speaker and check it's set to your main speakers, sometimes my computer will still be set to headphone out after unplugging them or if you've hooked up a Bluetooth speaker to it. another is check that one of your inputs isn't on solo which would silence everything else on that pc
