kricher1964
#1 Posted : Tuesday, March 5, 2019 4:13:41 AM(UTC)
kricher1964
Was thanked: 13 time(s) in 4 post(s)
When I add an object to a layer, it will sometimes reset the position to the upper-left-hand corner of the screen. I then need to re position it to where I had it prior. I consider this unexpected behavior. An object should not move just because I group it or change groupings.
