GT
Adding item to layer resets position - unexpected behavior?
Thanks: 4 times Was thanked: 13 time(s) in 4 post(s)
When I add an object to a layer, it will sometimes reset the position to the upper-left-hand corner of the screen. I then need to re position it to where I had it prior. I consider this unexpected behavior. An object should not move just because I group it or change groupings.
GT
