pesi
#1 Posted : Saturday, March 2, 2019 9:00:23 AM(UTC)
pesi
Canada
If I am doing MBR with the vMix encoder set up as follows:
#1 - 720p @ 2.5 Mbps
#2 - 720p @ 1.5 Mbps
#3 - 480p @ 650 Kbps
Which one of these streams will be the default being sent out to the ABR player at my CDN? #1 or #3?
What should the correct order be?
sinc747
#2 Posted : Saturday, March 2, 2019 2:20:20 PM(UTC)
sinc747
It probably depends on the stream key from your CDN assigned to each stream.
- Tom
pesi on 3/6/2019(UTC)
