Default stream in vMix encoder
Joined: 1/29/2017(UTC) Posts: 140   Location: Squamish Thanks: 54 times Was thanked: 4 time(s) in 3 post(s)
If I am doing MBR with the vMix encoder set up as follows: #1 - 720p @ 2.5 Mbps #2 - 720p @ 1.5 Mbps #3 - 480p @ 650 Kbps
Which one of these streams will be the default being sent out to the ABR player at my CDN? #1 or #3? What should the correct order be?
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
It probably depends on the stream key from your CDN assigned to each stream.
- Tom
 1 user thanked sinc747 for this useful post.
