NDI
Router 100mb + switch 1000mb
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi! I want to know if NDI will work fine on this setup:
-Router TP-Link TL470+ -Switch TP-Link TL-SG108
The router only will be used to balance the load over the WANs connections (NDI sources and vMix will be connected to the switch). So NDI will work? Or the router will down the speed of entire network? Thanks in advance!
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
Will work fine as long as your WAN speed is less than 100 mbps.
The NDI traffic will never see the router. It will be limited to between ports on the switch.
NDI
